BAAI
Recommend switching to newest BAAI/bge-base-zh-v1.5, which has more reasonable similarity distribution and same method of usage.
FlagEmbedding
Model List | FAQ | Usage | Evaluation | Train | Contact | Citation | License
English | 中文
FlagEmbedding can map any text to a low-dimensional dense vector which can be used for tasks like retrieval, classification, clustering, or semantic search. And it also can be used in vector databases for LLMs.
************* 🌟Updates🌟 *************
  • 10/12/2023: Release LLM-Embedder, a unified embedding model to support diverse retrieval augmentation needs for LLMs. Paper :fire:
  • 09/15/2023: The technical report of BGE has been released
  • 09/15/2023: The masive training data of BGE has been released
  • 09/12/2023: New models:
    • New reranker model: release cross-encoder models BAAI/bge-reranker-base and BAAI/bge-reranker-large, which are more powerful than embedding model. We recommend to use/fine-tune them to re-rank top-k documents returned by embedding models.
    • update embedding model: release bge-*-v1.5 embedding model to alleviate the issue of the similarity distribution, and enhance its retrieval ability without instruction.
More
  • 09/07/2023: Update fine-tune code: Add script to mine hard negatives and support adding instruction during fine-tuning.
  • 08/09/2023: BGE Models are integrated into Langchain, you can use it like this; C-MTEB leaderboard is available.
  • 08/05/2023: Release base-scale and small-scale models, best performance among the models of the same size 🤗
  • 08/02/2023: Release bge-large-*(short for BAAI General Embedding) Models, rank 1st on MTEB and C-MTEB benchmark! :tada: :tada:
  • 08/01/2023: We release the Chinese Massive Text Embedding Benchmark (C-MTEB), consisting of 31 test dataset.
Model List
bge is short for BAAI general embedding.
Model Language Description query instruction for retrieval [1]
BAAI/llm-embedder English Inference Fine-tune a unified embedding model to support diverse retrieval augmentation needs for LLMs See README
BAAI/bge-reranker-large Chinese and English Inference Fine-tune a cross-encoder model which is more accurate but less efficient [2]
BAAI/bge-reranker-base Chinese and English Inference Fine-tune a cross-encoder model which is more accurate but less efficient [2]
BAAI/bge-large-en-v1.5 English Inference Fine-tune version 1.5 with more reasonable similarity distribution Represent this sentence for searching relevant passages:
BAAI/bge-base-en-v1.5 English Inference Fine-tune version 1.5 with more reasonable similarity distribution Represent this sentence for searching relevant passages:
BAAI/bge-small-en-v1.5 English Inference Fine-tune version 1.5 with more reasonable similarity distribution Represent this sentence for searching relevant passages:
BAAI/bge-large-zh-v1.5 Chinese Inference Fine-tune version 1.5 with more reasonable similarity distribution 为这个句子生成表示以用于检索相关文章:
BAAI/bge-base-zh-v1.5 Chinese Inference Fine-tune version 1.5 with more reasonable similarity distribution 为这个句子生成表示以用于检索相关文章:
BAAI/bge-small-zh-v1.5 Chinese Inference Fine-tune version 1.5 with more reasonable similarity distribution 为这个句子生成表示以用于检索相关文章:
BAAI/bge-large-en English Inference Fine-tune :trophy: rank 1st in MTEB leaderboard Represent this sentence for searching relevant passages:
BAAI/bge-base-en English Inference Fine-tune a base-scale model but with similar ability to bge-large-en Represent this sentence for searching relevant passages:
BAAI/bge-small-en English Inference Fine-tune a small-scale model but with competitive performance Represent this sentence for searching relevant passages:
BAAI/bge-large-zh Chinese Inference Fine-tune :trophy: rank 1st in C-MTEB benchmark 为这个句子生成表示以用于检索相关文章:
BAAI/bge-base-zh Chinese Inference Fine-tune a base-scale model but with similar ability to bge-large-zh 为这个句子生成表示以用于检索相关文章:
BAAI/bge-small-zh Chinese Inference Fine-tune a small-scale model but with competitive performance 为这个句子生成表示以用于检索相关文章:
Frequently asked questions
  • Mine hard negatives following this example, which can improve the retrieval performance.
  • If you pre-train bge on your data, the pre-trained model cannot be directly used to calculate similarity, and it must be fine-tuned with contrastive learning before computing similarity.
  • If the accuracy of the fine-tuned model is still not high, it is recommended to use/fine-tune the cross-encoder model (bge-reranker) to re-rank top-k results. Hard negatives also are needed to fine-tune reranker.
For the bge-*-v1.5, we improve its retrieval ability when not using instruction. No instruction only has a slight degradation in retrieval performance compared with using instruction. So you can generate embedding without instruction in all cases for convenience.
Usage
Usage for Embedding Model
Here are some examples for using bge models with FlagEmbedding, Sentence-Transformers, Langchain, or Huggingface Transformers.
Using FlagEmbedding
pip install -U FlagEmbedding
print(similarity)
For the value of the argument query_instruction_for_retrieval, see Model List.
By default, FlagModel will use all available GPUs when encoding. Please set os.environ["CUDA_VISIBLE_DEVICES"] to select specific GPUs. You also can set os.environ["CUDA_VISIBLE_DEVICES"]="" to make all GPUs unavailable.
Using Sentence-Transformers
You can also use the bge models with sentence-transformers:
print(similarity)
Using Langchain
You can use bge in langchain like this:
    model_name=model_name,
    model_kwargs=model_kwargs,
    encode_kwargs=encode_kwargs,
import torch
model.eval()
# Tokenize sentences
# Compute token embeddings
with torch.no_grad():
# normalize embeddings
Usage for Reranker
Using FlagEmbedding
print(score)
print(scores)
import torch
model.eval()
    print(scores)
Evaluation
baai-general-embedding models achieve state-of-the-art performance on both MTEB and C-MTEB leaderboard! For more details and evaluation tools see our scripts.
  • MTEB:
Model Name Dimension Sequence Length Average (56) Retrieval (15) Clustering (11) Pair Classification (3) Reranking (4) STS (10) Summarization (1) Classification (12)
BAAI/bge-large-en-v1.5 1024 512 64.23 54.29 46.08 87.12 60.03 83.11 31.61 75.97
BAAI/bge-base-en-v1.5 768 512 63.55 53.25 45.77 86.55 58.86 82.4 31.07 75.53
BAAI/bge-small-en-v1.5 384 512 62.17 51.68 43.82 84.92 58.36 81.59 30.12 74.14
bge-large-en 1024 512 63.98 53.9 46.98 85.8 59.48 81.56 32.06 76.21
bge-base-en 768 512 63.36 53.0 46.32 85.86 58.7 81.84 29.27 75.27
gte-large 1024 512 63.13 52.22 46.84 85.00 59.13 83.35 31.66 73.33
gte-base 768 512 62.39 51.14 46.2 84.57 58.61 82.3 31.17 73.01
e5-large-v2 1024 512 62.25 50.56 44.49 86.03 56.61 82.05 30.19 75.24
bge-small-en 384 512 62.11 51.82 44.31 83.78 57.97 80.72 30.53 74.37
instructor-xl 768 512 61.79 49.26 44.74 86.62 57.29 83.06 32.32 61.79
e5-base-v2 768 512 61.5 50.29 43.80 85.73 55.91 81.05 30.28 73.84
gte-small 384 512 61.36 49.46 44.89 83.54 57.7 82.07 30.42 72.31
text-embedding-ada-002 1536 8192 60.99 49.25 45.9 84.89 56.32 80.97 30.8 70.93
e5-small-v2 384 512 59.93 49.04 39.92 84.67 54.32 80.39 31.16 72.94
sentence-t5-xxl 768 512 59.51 42.24 43.72 85.06 56.42 82.63 30.08 73.42
all-mpnet-base-v2 768 514 57.78 43.81 43.69 83.04 59.36 80.28 27.49 65.07
sgpt-bloom-7b1-msmarco 4096 2048 57.59 48.22 38.93 81.9 55.65 77.74 33.6 66.19
  • C-MTEB:
Model Embedding dimension Avg Retrieval STS PairClassification Classification Reranking Clustering
BAAI/bge-large-zh-v1.5 1024 64.53 70.46 56.25 81.6 69.13 65.84 48.99
BAAI/bge-base-zh-v1.5 768 63.13 69.49 53.72 79.75 68.07 65.39 47.53
BAAI/bge-small-zh-v1.5 512 57.82 61.77 49.11 70.41 63.96 60.92 44.18
BAAI/bge-large-zh 1024 64.20 71.53 54.98 78.94 68.32 65.11 48.39
bge-large-zh-noinstruct 1024 63.53 70.55 53 76.77 68.58 64.91 50.01
BAAI/bge-base-zh 768 62.96 69.53 54.12 77.5 67.07 64.91 47.63
multilingual-e5-large 1024 58.79 63.66 48.44 69.89 67.34 56.00 48.23
BAAI/bge-small-zh 512 58.27 63.07 49.45 70.35 63.64 61.48 45.09
m3e-base 768 57.10 56.91 50.47 63.99 67.52 59.34 47.68
m3e-large 1024 57.05 54.75 50.42 64.3 68.2 59.66 48.88
multilingual-e5-base 768 55.48 61.63 46.49 67.07 65.35 54.35 40.68
multilingual-e5-small 384 55.38 59.95 45.27 66.45 65.85 53.86 45.26
text-embedding-ada-002(OpenAI) 1536 53.02 52.0 43.35 69.56 64.31 54.28 45.68
luotuo 1024 49.37 44.4 42.78 66.62 61 49.25 44.39
text2vec-base 768 47.63 38.79 43.41 67.41 62.19 49.45 37.66
text2vec-large 1024 47.36 41.94 44.97 70.86 60.66 49.16 30.02
  • Reranking: See C_MTEB for evaluation script.
Model T2Reranking T2RerankingZh2En* T2RerankingEn2Zh* MMarcoReranking CMedQAv1 CMedQAv2 Avg
text2vec-base-multilingual 64.66 62.94 62.51 14.37 48.46 48.6 50.26
multilingual-e5-small 65.62 60.94 56.41 29.91 67.26 66.54 57.78
multilingual-e5-large 64.55 61.61 54.28 28.6 67.42 67.92 57.4
multilingual-e5-base 64.21 62.13 54.68 29.5 66.23 66.98 57.29
m3e-base 66.03 62.74 56.07 17.51 77.05 76.76 59.36
m3e-large 66.13 62.72 56.1 16.46 77.76 78.27 59.57
bge-base-zh-v1.5 66.49 63.25 57.02 29.74 80.47 84.88 63.64
bge-large-zh-v1.5 65.74 63.39 57.03 28.74 83.45 85.44 63.97
BAAI/bge-reranker-base 67.28 63.95 60.45 35.46 81.26 84.1 65.42
BAAI/bge-reranker-large 67.6 64.03 61.44 37.16 82.15 84.18 66.09
Train
BAAI Embedding
BGE Reranker
Contact
If you have any question or suggestion related to this project, feel free to open an issue or pull request. You also can email Shitao Xiao(stxiao@baai.ac.cn) and Zheng Liu(liuzheng@baai.ac.cn).
Citation
@misc{bge_embedding,
      year={2023},
      eprint={2309.07597},
      archivePrefix={arXiv},
      primaryClass={cs.CL}
Downloads last month
13,979
Safetensors
Model size
102M params
Tensor type
I64
F32
Inference Providers NEW
Model tree for BAAI/bge-base-zh
Quantizations
3 models
Spaces using BAAI/bge-base-zh 5
